Mikes Helicycle
Helicycle
Tail
3-23-2012
Tail fins, cabin halves
Set the horizontal fin incidence at 5 degrees using a .370 drill bit and the digital level zeroed to the main shaft.
Final torqued all the tail fin bolts being careful not to distort the thin spar tubes.
Pinstriped the right cabin half then installed it on the seat pan.
Horizontal stab angle set
Pinstripe on nose of right cabin
Right cabin half attached to seat pan
Helicycle Home
1363
Cabin
72
220
Drivetrain
116
Frame
Fuel system
Instrumentation
Main Rotor
Main Rotor
Paperwork
Tail
Tail Rotor
