Mikes Helicycle
Helicycle
Tail
3-17-2011
Tail rotor rigging
Drilled 4 safety wire holes in the tail rotor pitch slider.
Temp installed the tail rotor trans and tail rotor.
Had to add one thick washer to the left pedal stop to prevent the slider from hitting the tail rotor yoke.
Attached all linkages and adjusted for -8 to +18 degrees on the tail rotor blades.
Drilling safety wire holes
Full left pedal
Full left pedal 18+ degrees
Helicycle Home
Cabin
Drivetrain
Frame
Fuel system
Instrumentation
Main Rotor
Main Rotor
Paperwork
Tail
Tail Rotor
