Mikes Helicycle
Date:  1-8-2012
Number of Hours:  4.00
Brief Description:  Panel wiring
Continued working on terminating the wires to the lower panel switches and routing/bundling wires to make them better organized and secure.
Decided to change the Aux Governor switch from the current plastic switch with blade connectors to a better switch with screw connectors since I need to connect three wires to the load side of the switch.
Lower panel strain relief
Switches mostly wired
New secondary governor switch
