Mikes Helicycle
Date:  1-5-2012
Number of Hours:  1.50
Brief Description:  Fuel flow meter wiring
Just a short session tonight. Routed and connected the wires from the FS450 fuel flow meter under the seat pan and secured them with the rest of the wiring.
Cut several wires to length that will connect to the upper panel leaving enough length so the panel can be set on the seat for maintenance.
Fabricated a lexan cover for the terminal strip.
Lexan terminal strip cover
