Brief Description: Clutch position switch, oil pressure, hour meter
Made up the wiring for the clutch position switch, the oil pressure sender, hour meter and the oil pressure switch.
The hour meter ground is wired through the clutch micro switch and the oil pressure switch so the meter will only run when the engine has oil pressure AND the clucth is engaged.
