Added a small switch under the volt meter to allow switching between the main batteries and the small aux battery. Cleaned and sanded the two instrument panels then painted a satin almond color.
Drilled 8 mounting holes to attach the governor RF box to the back plate and installed nut plates with flush rivets on the back side of the cover.
