Mikes Helicycle
Helicycle
Installing control tubes
Installed the remaining four rivets in the pedal scissor arm bearing flange.
Final installed control tube ends torquing cross bolt nuts to 40 in/lbs.
Final installed the walking beams to the frame.
Installed the swash and attached the cotrol tubes ready to adjust travel and rigging.
Directional pedal arm
Walking beams installed
Control tubes from mixer to swash
Helicycle Home
1363
Cabin
72
220
Drivetrain
116
Frame
Fuel system
Instrumentation
Main Rotor
Main Rotor
Paperwork
Tail
Tail Rotor
