Worked on design and measurements for main trans lift strut.
Removed tail drive shaft sections until frame is painted for final measurement and drilling.
Inspected top trans bearing oil fitting in prep for adding small amount of oil into the bearing while turning trans to be sure the bearing stays oiled and rust free until painting is complete and oil added to trans.
