Mikes Helicycle
Helicycle
Left side wiring
Started working on the left side wiring which includes:
Transmission temp probe
Clutch position switch
Clutch actuator
Rotor RPM
Engine oil temp
Engine oil pressure sender
Engine oil pressure warning light switch
Hour meter (oil pressure/clutch engaged)
Main Fuel Solenoid
Governor main power
Governor backup power
Engine RPM pickup
Throttle potentiometer to governor
Wires and more wires
Helicycle Home
1363
Cabin
72
220
Drivetrain
116
Frame
Fuel system
Instrumentation
Main Rotor
Main Rotor
Paperwork
Tail
Tail Rotor
