Mikes Helicycle
Helicycle
Remove oil tank, safety wiring
Removed the turbine oil tank and capped the oil lines. The tank will now be leak tested then get painted pearl white.
Safety wired 10 bolts around the burner can and several screws and nuts on the fuel controller.
Safety wire twister for hard to reach areas
One of many
Smaller wire for the smaller screws
Helicycle Home
Cabin
Drivetrain
Frame
Fuel system
Instrumentation
Main Rotor
Main Rotor
Paperwork
Tail
Tail Rotor
