Mikes Helicycle
Date:  7-20-2011
Brief Description:  Oil tank vent, clutch
I came up with the idea to use a push connect fitting on the top of the oil tank cap for connecting the vent line so that I could more easily remove the cap and because it makes a tidy, compact install. Found a 1/8" NPT to 1/4" 90 degree that was a perfect fit and just had to enlarge and tap the hole I already had in the cap.
I decided to shorten the lateral clutch to frame brace by a few threads because with it as short as it will adjust, it is still pushing the clutch mechanism to the left of center which is placing a slight side load on the mounting ear on the bottom of the transmission.
Vent line fitting
Vent line fitting
Vent line in place
Vent line in place
Shortened lateral clutch brace
