Removed the sides from the engine crate and attached the lifting straps I made a few days ago to the top starter bolt and one of the gearbox case bolts. Tied a wire around the base of the main fuel solenoid mount as a third lift point.
Lifted the engine and crate base onto the work bench so I can more easily attach accessories and make up the oil lines.
