Mikes Helicycle
Date:  8-10-2011
Brief Description:  Clutch switch, governor
Finished fabricating the clutch switch mount and jeweled it.
Started laying out the governor box. The filtered terminal strip on the left will protrude from the back side of the plate and get wired to governor. This all has to fit inside the aluminum box cover which leave little spare room side to side
Switch plate final fit
Adding the bling
Adding the bling
Initial fitting of governor in its box
