Mikes Helicycle
Helicycle
Main Rotor
8-9-2011
Clutch actuator
Drilled and tapped two 3mm holes in the side of the clutch actuator housing for mounting a switch plate for the clutch engaged switch.
Drilled holes for mounting screws
Tapped for 3mm cap screws
Rough cut switch plate
Helicycle Home
1363
Cabin
72
220
Drivetrain
116
Frame
Fuel system
Instrumentation
Main Rotor
Main Rotor
Paperwork
Tail
Tail Rotor
