Installed Tee and fuel feed lines between the bottom tanks then connected the Tee to a temporary line and valve to close the system and provide a way to drain the tanks after the leak test.
Filled tanks with 18 gallons of gasoline, no leaks detected, left the fuel in the tanks for now.
