Mikes Helicycle
Date:  3-5-2011
Number of Hours:  2.50
Brief Description:  Lower fuel tanks
Finished installing the lower fuel tanks including the 3/4' hoses from the top tank into each of the lower tanks and the spreader plates on the bottom of the tanks.
Rotated the clamp on the trans drain line for better clearance and access.
Removed the swash plate for clear coating.
Pulling tank mount bolt
Tightening lower spreader plates
Tight fit for trans oil lines
