Mikes Helicycle
Date:  1-21-2012
Number of Hours:  3.00
Brief Description:  Capacitor wiring, drain fuel, cabin install
Made up a ground wire for the large capacitor I have on order and attached it to the terminal strip leaving the other end unterminated until I have the capacitor mounted in the pod. Once the cap arrives it will just take a couple of ring terminals and a few zip ties and the panel wiring should be complete.
Got some new stainless button head screws for the instrument panels that better match the instrument screws and are easier to install in the tight space at the bottom of the lower panel.
Drained the remaining gasoline from the tanks and filter sump in preparation for the jet fuel that will soon be in the tanks.
Reinstalled the right cabin half for a final fit check before painting. There are a couple of areas that will need some material removed to clear the frame and the sight gauge lower fuel line.
New button head screws for panel mounts
Right side installed again
Still hitting the frame here
