Mikes Helicycle
Date:  5-19-2011
Number of Hours:  3.50
Brief Description:  Chin window, cabin cut outs
Fabricated a couple of lift loops that can be bolted to the engine for lifting it out of the crate and onto the work bench then later into the frame.
Taped sanded and painted a 5/8" black border around the chin window.
Counter sunk the rivet holes in the door strike plates.
Marked additional cutout areas on the back of the cabin above the frame tubes on both sides. These areas are where the wires and fuel lines will exit the cabin
Lift loops for the turbine
Painting the chin window
Cutout for wiring and tail rotor cable
