Mikes Helicycle
Helicycle
Cabin
1-31-2011
Half Doors
Drilled and tapped screw holes in the three door latches. Turned down latch pins for the door latches. Started turning the pull knobs that will attach to the latch pins.
Cut excess material from the fiberglass door frames using the band saw.
Needs a knob
Turning the first knob
Cutting excess from 1/2 door frame
Helicycle Home
1363
Cabin
72
220
Drivetrain
116
Frame
Fuel system
Instrumentation
Main Rotor
Main Rotor
Paperwork
Tail
Tail Rotor
