Mikes Helicycle
Helicycle
Cabin
1-28-2011
Door latches
Located and drilled screw holes in three door latches and tapped so that exposed nuts will not be needed, started machining pull pins for latches.
Turning latch pins
Tapping latch housing
Helicycle Home
1363
Cabin
72
220
Drivetrain
116
Frame
Fuel system
Instrumentation
Main Rotor
Main Rotor
Paperwork
Tail
Tail Rotor
