Mikes Helicycle
Helicycle
Cabin
1-8-2011
Pod brackets, seatpan removal
Located and drilled front pod to seatpan bracket, installed nut plates, drilled and counter sunk backing plate.
Removed instrument pod.
Drilled rear pod to seatpan bracket for five 1/8" rivets.
Adjusted two frame tabs under right side of seatpan so they sit against the fiberglass without pulling when the bolts are tightened.
Removed seatpan from frame.
Helicycle Home
1363
Cabin
72
220
Drivetrain
116
Frame
Fuel system
Instrumentation
Main Rotor
Main Rotor
Paperwork
Tail
Tail Rotor
