Mikes Helicycle
Date:  5-26-2012
Brief Description:  Labels, engine alignment
Applied several more labels including:
- Two Jet-A / usable fuel labels
- HOT warning label near engine
- Two oil filter part number labels
- Tail gearbox oil type label
- Fragile label on throttle arm
- No Push label on door sills
Lowered the rear engine mounts 1 turn to re-align the pulleys after having added a turn to the clutch clevis a couple weeks ago to bring the clutch pull up to 45 lbs from 35 lbs.
Jet-A labels
Jet-A labels
Appling warning label to frame
Lowering rear of engine to align pulleys
