Mikes Helicycle
Date:  4-16-2012
Number of Hours:  1.50
Brief Description:  Rear blade support
Finished up the rear blade support, flattened the ends of the tubes and drilled holes to match the holes in the frame tabs. Applied 3M paint protection tape to the frame tubes and tabs where the blade support will attach. I just need to find some thin foam to line the inside of the cradle and this support is done.
Total build time now: 925 hours
Rear support almost done, just needs foam
