Mikes Helicycle
Date:  12-31-2011
Number of Hours:  6.00
Brief Description:  Still more wiring
Ran the wires from the exhaust temp probe up to the front. I attempted to secure the wires so they have good clearance from the hot turbine burner can.
Final installed the wires to the regulator/rectifier.
Ran the wires from the rotor RPM pickup down to the panel along with the main trans temp probe wires.
Deciding on routing for the exhaust temp wires
Routed and secured
Routed and secured
Regulator/rectifier
Regulator/rectifier
