Mikes Helicycle
Date:  8-24-2011
Number of Hours:  1.00
Brief Description:  Rotor tach pickup
Installed the magnet ring on the main shaft and test fit the rotor tach pickup bracket. Decided to remove 3/8" from the back edge of the bracket so the pickup can be mounted closer to its middle for better adjustment range and harmonic balance.
Checking the fit
Checking the fit
