Brief Description: Engine Control Cable Mounts Part 2
I used a scrap piece of stringer material for an alignment tool so the brackets would lay flush to the instrument panel. Once the positions were marked and the pieces clamped in place I tacked the sides. After removing the chunk of stringer material I finish welded them in place. After all that, I put the instrument panel back in and match-drilled the holes in the brackets to the panel. Looks great!
