Today I finish welded the rear bushings, trimmed all the bushings to size and cleaned up the threads. Once that was done, I took My friend Rob Taylor’s factory seat and set it inside. I made a simple jig that rests on the cargo door sill that sets the height and angle of the seat bottom of my seat using his seat as an initial reference. Once that was out I just set my seat inside to see how it looked in place. Since the seat is already complete all I have to do is set the legs in place and tack them to the frame. It is really easy having had a factory example as a pattern. Thanks Rob!
