Not much to show except the back clusters and diagonals were finish welded. I did leave the backside where the T10 leg is attached unwelded. The front seat tube is just tacked for now. This is a strange cluster with three tubes of different sizes coming together at odd angles. What I’ll do is position the front seat legs once the seat is jigged in place and tack the legs. Once the legs are tacked I’ll break the front seat tube tacks and weld the T7 legs all the way around on the T10 tube, then refit the front seat tube. I feel that will be the best way to give this cluster the maximum strength it needs.
