Finally back at the project! I was able to use my new brake and make the sheet metal panels that go between the two front seats. I also was agonizing on the best way to get all those seat tracks aligned and even with each other. The only way was to connect them somehow and then it occurred to me…why not use some 5/8ths plywood and make spacers the hold the tracks completely straight and parallel in relation to one another. After the tracks are tacked in place, I can just cut the plywood out and the tracks will be perfect! After a bunch of layout and jigging, I finally got all the parts and pieces to be perfect in relation to one another. It was late when I decided to wait until the morning to tack the tracks in place. The outboard tracks will need spacers at the forward end due to the diagonal tubing they are welded to going up and away from the centerline.
