A couple of pictures that give a good overview of the fuel system. Fuel flows from the left and right tanks and the lines meet at the fuel valve. The line from the outlet of the fuel valve then runs to the gascolator, boost pump pre-filter, EFii boost pump and then to the firewall. Very clean setup. Jim Harden's handywork. All I did was advise on layout and made the component mounting tabs. Thanks Jim!
