Brief Description: Fuel Tank Cross Vent and Grounding tab
I welded up the second filler neck and polished it smooth. While I was set up for welding AL, I decided to weld the bosses on the main tanks for cross-venting them. I put it as high as I could on the tank and still have the fittings clear the adjoining rib. It all came out nice. I also welded on tabs to all four tanks to ground them to the wings instead of relying on the fuel lines for a ground…much safer that way!
