This is another project that I have been putting off for far too long. How do I connect the brake cylinders with the fluid reservoir and still move the rudder pedals? I didn’t want the reservoirs on the brake cylinders as they are a pain to check and service. Plus, I already had a fluid reservoir mounted on the firewall. I went with some Stratoflex 193 line, a tee fitting and mounted it to a bracket I made, clamping it to a fuselage crosstube on the firewall. It seems to work fine and not impede the movement of the rudder pedals. Moving on…
