I'm getting ready to make the fittings that hold the landing gear to the fuselage. I'm using a set of gear from Avipro, so the building sequence needs to be changed a bit. Someone on our group posted a picture of a landing gear fixture that was made for what looks like a PA-12. It was really nice, but way overkill for my application. So I took the idea and adapted it for making a jig to hold the gear legs in the proper position while I tack the fittings in place. This will allow me to make sure the gear is at zero toe and aligned with the fuselage.
