Brief Description: Vertical Stabilizer Ribs Part 2
After spending MORE quality time on the tractor moving snow and then having it start to snow again, I was able to get in the shop for a little more.
I was able to fit the two ribs and the T5 diagonal tube. I located where the tube would intersect the rib and drilled a lightening hole. It lined up just fine. I ended up marking the ribs for the lightening holes and pilot-drilled each location. If it doesn't snow too much tonight, I will be able to finish the ribs, tack everything and hopefully start to finish weld the stab.
