I spent some time moving snow today, but did just the minimum as we're supposed to get more this weekend.
I was able to fit all the pieces for the rudder, tack them in place and then finish welded the assembly. I'm really happy how it turned out. It got pretty late, so all I did was cut the T1 tubes for length. I'll finish fitting and welding them in tomorrow. There are two more things to add to the rudder. One is the fitting for the tail light and the other is to make provisions for a place to mount a trim tab. I polled the BH group and only received a couple of responses so far whether you need something like that. The good news is I don't need an answer right away and I can always add something in the future before covering.
