Alaskan Bearhawk
Date: 11-20-2011
Number of Hours: 6.00
Brief Description: Making Elevator Trim Belcranks
Boy, this was another one of those "simple" projects that took awhile. First, I wanted to drill the hole for the bolt that holds the trim horn to the tube, but I didn't have any way to make sure it was in the center. So, I made up a vee block with a centering hole so I could drill in the center of tubing all the way through without any offset. That took awhile. Then I cut out a set of plates, made bushings, drilled them and welded and I didn't like the way they turned out. So, I made another set. This time I was happy with them. Man, if I ever build another Bearhawk, it will only take half the time!
The holes for the drive tube bolts are offset a little so they can be removed/torqued with the other bolts in place. I saw Eric Newton did this on his project and it made sense. No particular degrees, maybe 25to 30, and the bolts are still pointed down.
Ready to tack
Hole offset to torque nuts
Done
