Brief Description: Tidying up Wires Behind the Panel Part 3
The left side was the easy side, now on to tackle the part behind the breaker panel. As much as I would like to make the wiring look like those in the magazines, it’s not going to happen. I started by sorting out the wires that I could. I found that ground wires were the main culprit in weaving through the bundles and making it difficult to make nice looking bundles. So I disconnected them all. I unwove the ground wires where I could, and used extra space on the spade terminal connector block for the few ground wires still needing a home.
