Not much to report, although a lot has been done. I drilled and deburred all the holes for the main tank cover nutplates. I tinkered around and found a faster way to deburr all those holes. I took the #40 countersink bit out of the microstop, put it on an extension and then on my angle drive drill. Easy does it with pressure and RPM, but it went MUCH faster this way! I swear, I could build a Bearhawk in a third of the time...next time!
