Alaskan Bearhawk
Date: 11-11-2008
Number of Hours: 0.00
Brief Description: Cleaning the crank Part 2
The brush in the drill motor worked really slick, as did the scraping tool I made. I turned on the radio, got comfortable and took my time with the brush and scraper. II would scrape with WD-40 as lubricant, then flush with brake cleaner. I repeated this about 5 times before I was satisfied it was as clean as I could get it. I was very careful cleaning around the oil tube! I flushed it one more time with brake cleaner, then I used a high quality lint-free pad and scrubbed as best I could using the tip of the long screwdriver to wipe the inside. One more flush with brake cleaner, then I hit it with some compressed air. It turned out really nice, There are pits from rust in the plug, but it's clean.
After I was satisfied it was the way I wanted it, I stood it up on an engine stand, put in a couple of bolts and sprayed it everywhere with LPS-3. It will be there until the solvent in the LPS-3 evaporates. Then, I'll put the bag back over the crank and put it back in the box it came in, ready for when I put the engine together.
BTW - Happy Veteran's Day today to all! Thanks for your service. NONE of this would have been possible without you and those before you.
Brush on the mandrel
Nice and clean!
Sprayed with LPS-3 and ready for storage
