One last thing to do on the engine is to figure out some type of support for the prop control cable. There was quite a bit of unsupported sweep between the last adel clamp and where it mounts to the engine baffle. Jim Harden was concerned the cable would vibrate and as a result contribute to premature wear at the baffle attach point. I came up with this bracket that shortens that distance and it really helped stiffen up the sweep area.
