Brief Description: Firewall to Exhaust Tunnel Transition Part 2
I had to split the pieces because I had to go around the crankcase vent tube that was already in place. I used a strap duplicator to find the firewall to exhaust tunnel screw holes and it worked perfectly. Once all the fitting was done, it’s now time to rivet the top edge to the firewall. I am really happy with the result. It looks good and should help with the engine cooling.
