One thing I wanted to check was the clearance between the engine air scoop and the Vans FAB airbox. I got some putty and stuck it to the bottom of the airbox and then fit the scoop where it would live. I took the scoop off and then measured the blobs. I had a very even 3/4in of clearance across the bottom! That’s really good as I still have to install the alternate air door.
