Well, this isn’t fun. After bleeding the brakes I thought all was good. After a few days I noticed some hydraulic fluid on the floor.. I found that the brake line where it connects to the fitting under the pilot’s seat was leaking. In addition to that, there was hydraulic fluid leaking out of the lower landing gear fabric. That meant only two places that it could be. The B-nut at the top of the gear leg and the one at the bottom. I was able to sort out the leak under the pilot’s seat. The other will need some surgery on the fabric…nothing I am looking forward to.
