I leveled the fuselage in the rotisserie in preparation of welding on the gear leg fittings. Because I'm using Avipro gear, I have to reverse some of the building process. In this case, I have to make sure the gear matches the fuselage and also the landing gear fittings.
I got the landing gear in the jig I built and slid it under the fuselage. After a little fiddling, the gear lined up perfectly and had the proper distance from the lower longerons. Now I have to build the gear fittings.
