Well, it's finally over. I sanded the first coat then sprayed the second coat of primer. Sanded the second coat and fixed any little issues that normally pop up at this stage in the process. I cleaned it nicely and sprayed three coats of topcoat. It turned out just fine. Here are a few spots here and there that I noticed that could be touched up, but will leave them alone. They won’t be noticed by anyone but me! After the paint had set up, I took off all of the tape, foil and plastic. It was like Christmas! The color it just a tiny touch lighter than the tubing topcoat, but it’s just fine. On to other things…
