Brief Description: First Primer Coat Prep for Second
Again, not much to say here other than this is just a lot of grunt work in the prep process. All the primed parts get wet sanded. It is very tedious. I have to take off just enough without sanding through. It’s a time bandit for sure. I put 10 hours on this log to cover all the other parts. It’s probably more than that, but so be it. I found that a spray bottle of pain water worked very well and eliminated a HUGE mess in the shop
