It took a bit of thinking to sort this out. I had to figure out the best routing of the pitot static lines and still have room for the other things in the back of the panel. One other device that isn’t shown is the altitude encoder. It also needs a static connection. I don’t quite know where it will live behind the panel, but it will be connected with a static line.
One thing that is interesting about the installation kit I bought is the different colored lines. Green is for pitot, white for static. Also, the stuff isn’t that flexible. I played with some chunks of line and a heat gun until I got the proper bends. I wanted to have the tubing slide in and out of the fittings without using any force.
