Part three of this WWF smackdown of firewall vs builder. I spent almost 10 hours on this firewall so far and I still haven't got it tacked! I did weld the ends and got it on the fuselage, but when I got it all locked down and steady, it was a little off. The centerline is perfect, but the thrustline/engine is off a bit in elevation. It's a little hard to describe, but if I were to do it over, I would have made my own mount. I'm into this at around ten hours and it's still not done! Very frustrating...
The mount, when perfectly aligned and where it should be has the engine horizontal centerline a hair above 1/16th above where is should be with all the point locations locked down. Very frustrating...off to bed.
