Alaskan Bearhawk
Date:  12-13-2008
Number of Hours:  3.50
Brief Description:  More Welding Practice Needed!
Today was rather frustrating. No, wait, REALLY frustrating!!! I had welded the seam closed on the station M cross tube and wasn't satisfied at ALL with the weld, so I decided to do some DT and practice some more. The cross tube has to be welded before the other tubes are fit to it. For whatever reason, I could not draw a straight bead to save my life. I was overheating the tube, even though I had the smallest tip I had on my torch, it was popping, blowing through...you name it. I'm no doubt a beginner, but I had practiced a fair bit before and didn't have near the problems I'm having now.
I decided to just tack the cut in the new cross tube for now and fit the other tubes to it. I can keep going with fitting other stuff and practice some more. Then, when I'm more satisfied with the quality of my welding I'll come back and finish weld it.
I look at the welding books and see those fabulous welds that others have done an am in awe. All I need is practice, practice, practice, practice, practice, practice, practice, practice, practice, practice, practice, practice, practice, practice, practice, practice, and practice,
First weld cut open
First weld cut open
Second practice...fracture
Using my new tubing holders to practice.
