Brief Description: Lower Wing Strut Fairings Part 3
It took a bit of doing, but they are done. I used the cut off pieces of lift strut to hold the shape while the Chem Seal on the inside set to hold things together, and for added structure I embedded little aluminum wedges. Trying to make a curved rivet flange all the way around using one piece of 2024-T3 was way beyond my patience level. As it is it took five days to make both sides. Once painted they will have some rubber channel along the edge.
